Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 1999
    Location
    Oklahoma, USA
    Posts
    43
    Cummins Stroker 6.7L Kit?
    Although the information is hard to find, there is a Cummins 6. 7L B Series engine available for the Ag market. It appears from the bore & stroke callouts that only the stroke is increased. I wonder if you could purchase the crankshaft and connecting rods from Cummins (provided we had the part numbers) and bolt it up? It may require modifications to the engine/oil pan, but wow, how unique would that be? Cummins 6. 7L Diesel!!
  2. #2
    Join Date
    Jan 2000
    Location
    Buckeye, Az. USA
    Posts
    898
    HMMM! A stroker kit for our strokers! 6. 7L ciphers to ~ 407 C. I. and ~ . 640 longer stroke. I wonder if the piston bowl would work with the 5. 9 head chamber CC - ie. comp ratio. Craig
  3. #3
    Join Date
    Dec 2002
    Location
    Corvallis, OR
    Posts
    4,543
    You'd have to cut back the rpm a little but I like it. Personally I doubt it's in the same block though. With that much throw in the crank you'll be mighty close to smacking the bottoms of the cylinders with the sides of the rods.
    -Scott
  4. #4
    Join Date
    Jul 2004
    Location
    Logan County, Oklahoma
    Posts
    33
    There is a 6. 7L that will be available next year for the ag market. It is a tier III engine. Yes the block is different than the current ISB with the HPCR engine but the head is the same. This engine has been in Europe for the past 2 years. Buy a new block, crank, connecting rods and you'll be in business-don't hope to get these parts until middle of summer next year on '05
    2005 RAM 2500 Laramie Quad Cab 4x4 LWB NV5600 FLAME RED
    SOLD! 2001 RAM2500 Quad Cab Long Bed 4x4 235hp 5 Speed Banks PowerPack Driftwood 285/75 R16 BFG KO Cummins 24v Red Valve Cover MAG-HYTEC - 135,418 miles
  5. #5
    Join Date
    Apr 2004
    Location
    S.W. Missouri
    Posts
    572
    I was at a farm show this past weekend and there was an Agco tractor that had the 6. 7 in it. It wasn't intercooled and it wasn't a common rail, the pump actually looked very similiar to the one on my 91. The blocked looked different too.
    2004.5 3500, 4x4, Bone Stock!!!!!!
    91 Dodge W250, 4x4,Cummins 300,000 mi. still purrs like a kitty
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
