Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 10 of 10
  1. #1
    Join Date
    Mar 2002
    Location
    Arcanum, OH
    Posts
    486
    Should i cover up my radiator?
    It is going to drop down 15 below zero on Christmas out here in Ohio. Luckily I keep the truck in a garage.
    Gary
  2. #2
    I assume you're referring to covering it when its being driven to keep the heat up
    The slickest, cheapest radiator cover I'm aware of (and have used every winter since I've owned the truck), is a piece of cardboard cut to fit between the intercooler and the radiator. It drops in from above. Cut about an 8" or 9" hole slightly off center in the middle so the fan clutch gets air. This allows cool air to pass through the intercooler but blocks much of the radiator. It lets the engine get warmer faster and helps keep it at proper temperature. Just be aware if the temps get in the 40s or 50s and you get flyin' down the freeway, up a long hill, or tow something, you may have to pull it out.
    -Jay
  3. #3
    Join Date
    Nov 2000
    Location
    Grand Rapids, Michigan
    Posts
    4,995
    Actually it is a good idea to cover the intercooler also otherwise the intake temps can get too cool. I wouldn't recommend a piece of cardboard directly in front of the IC but a set of grill covers will work nicely.
  4. #4
    Join Date
    May 2000
    Location
    Salt Lake City, Ut., USA
    Posts
    3,716
    Guys, see my Winter guards in the member basement Classified area. Make sets for the 2nd and 3rd gen Reg and Sport.
    Lets air in up to 60 deg but warms up faster so there is no overheat.
    New 2009 SXT 3500 LB. Bright Silver..Stock for now. Rhino Liner, Ricksons 19.5" rims andToyo 225/70R-19.5" tires.. "G" Rated,. 14 ply.. Stock 17" tires in winter ..Self Made Winter fronts... Truck name is Silver Bullet!
  5. #5
    Join Date
    Jan 2004
    Location
    Havre, Montana USA
    Posts
    74
    It was -22 yesterday morning here in Northern Montana and I finally put my cover guard on my grille. My truck is also garaged and plugged into a timer so it will be warm when I go out. I bought a stainless steel 4 piece cover that fits nice and looks good.
    Today it is 35 as I type this?? Oh well. Have a Merry Christmas and Happy New Year.
    Mike
  6. #6
    Join Date
    Jul 2000
    Location
    Pueblo West' Co.
    Posts
    139
    Cover it up, but not completly, need to leave a little air to the charge air cooler.
  7. #7
    Join Date
    Mar 2004
    Location
    Anchorage Alaska
    Posts
    570
    The grill is blocked off and I put a peice of cardboard between the IC and radiator. Works good. I remove the cardboard when I tow. Works good, just watch the temp gauge.
  8. #8
    Join Date
    Nov 2000
    Location
    Posts
    4,995
    I run with the grill blocked and remove the fan. I guess it just depends on how cold it get where you are located.
  9. #9
    Join Date
    Mar 2003
    Location
    Kenai Alaska
    Posts
    130
    I run the lund grill covers myself and have been really happy with them. The 2 ports in the bumper make the biggest difference. I usually run the bumper covers and two of the grill covers. just my $. 02
    Regards,
    Nathan <><
    "God's work done in God's way will never lack God's supply" --Hudson Taylor
    _________________________
    2002, 4x4 Dodge Ram 2500, HO 6spd, Quadcab ST, sitting on 10ply 305/70/16 Toyo Open Country A/T's w/2"Daystar leveling spacers, Westin nerf bars and stillen fender flares.
  10. #10
    Join Date
    Aug 2001
    Location
    IDAHO
    Posts
    1,177
    i got eric bu's winterfronts on my rig. i had a set of his fronts on my last 4 rigs btw. look great and work great. helps warm up and lets enuff air in for the innercoolr
    definately good idea to have something when its cold
    97 DRW CLUBCAB FLATBED. 385 RWHP/837 RWTQ
    98 12V QUAD CAB 4WD.
    03 QUAD CAB 4WD
    previously owned 19 DODGE CUMMINS trucks.
    FOR IDAHO TDR CHAPTER EVENTS CHECK NORTHWEST EVENTS AT TDR AND WWW.IDAHOTURBODIESELS.COM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
