Results 1 to 3 of 3
  1. #1
    Join Date
    Oct 2001
    Location
    Chatham, Illinois
    Posts
    2,980
    4BT conversion - throttle linkage
    I'm ready to start the swap and am going from a VE pump to the p- pump and need linkage or idea's to get this working with a chevy P-3500 truck. The pump does have a lever on the splined shaft, But I need to take it from there.
    Who has crossed this issue, and what did you do?
    1998 quad 4X4
  2. #2
    does your truck have a throttle cable? if so just make a brcket to hold the housing and put a ball on the lever.
  3. #3
    Join Date
    Oct 2001
    Location
    Chatham, Illinois
    Posts
    2,980
    Yes it uses a cable. I hope it is that easy. I think I need to extend the lever to get correct cable travel.
    I was hoping someone had a known set-up that would bolt on it.
    1998 quad 4X4
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
