Thanks Thanks:  0 Likes Likes:  0 Dislikes Dislikes:  0
Results 1 to 14 of 14
Thread: Cummins Coolant filter kit for Dodge?
  1. #1
    User Info Menu
    Question Cummins Coolant filter kit for Dodge?
    The question came up in my shop class the other day by one of my students. He wanted to know if anyone manufactured a coolant filter kit for Dodge pickups equipped with the CTD. Does anyone know if such a kit is available by Fleetguard, Wix, Donaldson ?
    Surely someone is running one on their Dodge?
    Thanks !
    1999 2500 Q-Cab 4X4 long bed auto trans School shop project truck
    2001.5 Q-Cab 4X4 long bed auto
    2006 Jeep Liberty CRD belongs to my youngest daughter
  2. #2
    User Info Menu
    I would think a universal kit could be made to fit, however it is not necessary on the 5. 9.
    "NICK"
    74F350 4x2w/90ctd, 5spd Clark w/3spd Spicer-aux, aftercooler w/#16 hsg, 8.5cfm Holset air comp, air horns, seats, Pacbrake, overloads, maxi brake, 5"stacks, aluminum bed. 01 quad cab 4x4, 6spdw/3.55, 275s, edge juice w/attitude, 4" MBRP, BD brake. 91.5 D250, 5spd, 50 hp inj. #16, pac brake.
  3. #3
    User Info Menu
    Sand and sediment
    This might be true but it would do absolutely no harm to add one to the ISB. These are sand cast engines so there is always some casting sand, silica and sediment that dis-solves, seeps out of the cast iron and contaminates the cooling system and water pump. All over the road, stationary diesels have them installed so, why not the little ISB ?
    Surely, someone has tried this or knows of where a kit can be purchased. This is a shop class project so we will give it a go. Thanks for your input.
  4. #4
    User Info Menu
    Quote Originally Posted by RACE427
    All of them have one?
    I'm just guessing here, but most larger diesels are sleeved, not parent-bored like our 5. 9 is. I'm told that coolant issues are a much more significant with a sleeved engine. It stands to reason, I suppose.
  5. #5
    User Info Menu
    Water pump life
    If you can filter out all of the sand, silica, sediment and impurities from your cooling system just think how long a water pump could last. People spend thousands of dollars to make more power but they will not spend a little bit of money to help the longevity of the engine and it's components. Go figure.
  6. #6
    User Info Menu
    Water pumps are cheap ($50) and easy to replace on our engines. . .
    Matt
    His: '94 2500 4x4 12V, NV5600, SBC Con FE, NP241DHD
    Project: The Jeep is gone...now what???
    His/Hers daily drivers: '99 Benz E300 TD, '00 Jetta TDI
    Dad's: '98 2500 4x4 12V, Massdiesel DTT 47RE
    R.I.P. Nowel "HVAC" Thomas, Greg Boardman
  7. #7
    User Info Menu
    . . . . . and how frequently do water pumps fail on the B-series Cummins?
    Rusty
    2016 Ram 3500 Longhorn 4x4 Dually crew cab long bed, white with tan/brown leather, 385/900 Cummins, Aisin AS69RC, 4.10LS, B&W Companion RVK3600 5th wheel hitch
    2014.5 DRV Mobile Suites 38RSSA 5th wheel
    2007 BMW K1200GT - BMWMOA 120519; 1971 Honda CB750K1
  8. #8
    User Info Menu
    Shop class project
    Guess I did not fully explain myself. This cooling system filter is for a shop class project truck. I use this install to teach kids how to install cooling system filter kits. As I posted before, cannot hurt the engine.
  9. #9
    User Info Menu
    Nope, it won't hurt the engine. What the other posters are saying is that, for the B-series Cummins, it solves a problem that really doesn't exist.
    Rusty
  10. #10
    User Info Menu
    Race427 a coolant filter kit can be purchased, the one i have is waiting to be put on a Multifuel military engine when installed, the kit is a Napa the filter housing has to be purchased and is #4019 and the filter itself is Napa Gold #4070, the filter housing comes with your elbows and mounting hardware for around 50$, it also has directions for hooking up the filter setup. I think that is what you were asking for, i am planning on putting one on each of the dodges, no matter if they need them or not, will definetly help with scale build up in the radiator.
    These are universal there is really no one specific to fit either ford, dodge, chevy etc. . .
    1968 AM General M35A2 6x6 (2.5 ton truck), so to be transplanted with new LDT 465- 1C engine( diesel of course)
    11/28/05 1992 12V, W250, 5 speed,4X4, lwb has power mirrors, windows, locks, sliding back glass and Cruise control.
  11. #11
    User Info Menu
    It's not an issue with the B series. Put your time, money and effort into something else more meaningful. Teach em how to build twin turbos and such.
  12. #12
    User Info Menu
    Filter Engineering makes a coolant filter for the B5. 9 Ram. They have no webpage. See this thread post #6.
    http://www.turbodieselregister.com/f...er+engineering
    Filter Engineering Incorporated
    1499 Pomona Rd Ste B
    Corona, CA 92882-1714
    (951) 737-5690
    Bill R
    '94 2500 SLT 4x4 5 Speed, 3.54 LS, JRE 4" exhaust, DD Stage III injectors, TST #0, PDR HX40, Southbend Con 0
  13. #13
    User Info Menu
    The main reason for coolant filters, is the treatment/chemical that is in them for electrolysis prevention, an inherent problem with sleeved engines. However, like you say, it can't hurt and very well might help clean up water contamination.
    "NICK"
  14. #14
    User Info Menu
    It can hurt! Most coolant filters contain an additive to condition the coolant which is fine if you are running conventional coolant as long as you do not over supplement this can cause blockage. If you are using extended life coolant (which is what most new diesel engines are shipped with) the additive in the filters is not compatable with ELC. Cat's ELC requires an extender additve every 2000hrs I believe and then is good to 6000 hrs. I have not seen coolant filters on highway trucks or off road diesels for quite a few years. Using a coolant filter with the standard additive in an ELC system will dilute it over time and once its over 10% the benifit of ELC is gone and it needs to be treated as conventional coolant. If you wish to maintain your conventional cooling system get a test kit from NAPA or the like and add suppliment as needed. JMHO
    "I'll say it to your face,Man!" (Donnie Baker)
    '11 W-Gold Laramie 3500 CCLB 4X4, 35" Toyo M/t's, BW Flares, Rhino Nerfs, Fusion Bumper, Cab lights.
    (Traded)06 Inferno 3500 QC 4x4 SRW H-pkg. Laramie CTD auto LSD bucket seats 35"ToyoM/T's
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
