Page 1 of 2 12 LastLast
Results 1 to 15 of 28
  1. #1
    Holset H1C exhuast housing size
    Could some one help me out on this one please, I'm tring to determine the exhaust housing size on my H1C turbo, 1990 5. 9 engine, the turbo had be rebuilt prior to me purchasing it 4yr's ago, The turbo/exhaust housing is still in the truck but with a trouble light and a mirror I've located and jogged down some casting numbers, Here goes on the front side of the exhaust housing there is a casting stamp # 2 J 8, on the back side the casting stamp reads Holset (with a large raised letter A ), then closer to the exhaust flange the casting stamp #'s are TW1, 5538055 ( I believe this is the identification # 5538055 ) then there is also the # 12-128-01, Like I stated I'm reading this by use of a mirror so there may be a mistake in my # identification but I believe them to be true, Any help or finger pointing to an known Link will be a definite asset,
    Thanks fella's
  2. #2
    Join Date
    Jan 2003
    Location
    Las Vegas
    Posts
    5,343
    Should be some more numbers on the back side of the exhaust housing, IIRC the 90's had a 21 sq cm housing. Therefore, you would see 21 somewhere back there, or in the case of an 18. 5 sq housing 18 or 18. 5.
    '03 3500 QC DRW 4WD 6SPD..SB DD3250 ,PMCR, aFe,torque tube,DD 2's,SPS 62/14, 4" exhaust, Titan,GN & 5'er hitches ,Autometer Phantom II pyro/boost ,XM radio .'93 W250CC ,NV4500, DISTRIBUTOR OF THE CHALLENGER & DOMINATOR CAR HAULERS, OWNER/OPERATOR OF DOUBLE M TRANSPORT
  3. #3
    That's the numbers 21/18 that I was expecting to find on the exhaust housing, No luck, only the numbers stated above
  4. #4
    Join Date
    Jan 2003
    Location
    Las Vegas
    Posts
    5,343
    Give it time, I'm sure someone here will chime in.
  5. #5
    Join Date
    Oct 2005
    Location
    Sioux Falls, SD
    Posts
    696
    Inside the exhaust runners is an indented casting. Usually goes unnoticed until close inspection, removal would be necessary. . .
  6. #6
    Join Date
    Jan 2001
    Location
    Cape Girardeau MO
    Posts
    4,362
    If it is stock, it has an 18. 5. If not, who knows.
    Daniel
  7. #7
    Quote Originally Posted by dpuckett
    Daniel
    Ok more info from my end this may not amount to much but the turbo had been rebuilt, before my purchase of the truck! But I would think every thing is still OEM the compressor/exhaust turbine/housings, The tag location on the compressor outlet has a reman identification tag, but those # don't jive either,
    How about a physical size difference can the size be determined by measuring the Width/height of the exhaust housing
    Some may wonder what the biggy is about this exhaust housing!
    I'm looking to upgrade to a 16cm2, but I sure would hate to start an R & R and purchase a 16cm2, only to find that the turbo is 16cm2 equiped
  8. #8
    Whoops there is a number on reman tag that might help Assembly# 3526739,
    Kit# 802302RX, This is a Cummins remanufactured identification tag, I hope this helps U help me,,, Thanks
  9. #9
    Join Date
    Dec 2006
    Location
    SW, Ohio
    Posts
    7
    Quote Originally Posted by THeske
    The 3526739 indicates it's a 18 cm2. I'll try to find a link for you later, I downloaded the pdf at some point.
  10. #10
    Thanks guys I found a link that suits my purpose:
    TRANSMISSION: AUTO/MANUAL
    YEAR: 1990
    ENGINE: 160 HP
    ORIGINAL PART NO. 3528771
    CUMMINS PART NO. 3802302,3802148
    HOLSET PART NO. 3526739
    C. H. R. A. PART NO. 3523317
    FRAME SIZE: H1C
    TURBINE HSG. SIZE: 18 cm2
    However the exhaust housing may have been changed during this rebuild! without a exh housing casting stamp that Identify's it as a 18cm2, It may still be something else but I will assume it's a 18cm2, I may have one up for sale if it does turn out to be a 16cm2
  11. #11
    Well I'm back to square one on this one guys, I purchased a modified hx35 turbo with a 16cm2 exhuast non-waste gate, the fella I bought it from said it was a Piers diesel modified turbo, The casting number on the back of the turbo looks like a 16 but the casting number inside the exhaust port looks like 18, anyways this is my delema, the exhaust housing on my truck should be a 18cm2 according to the rebuild tag but it is actually smaller in physical size than the HX35 modified exhaust housing, Can there be a smaller physical size diff and still have more cm2? I did a real rough measurement on both housings the hx35 is about 6" across and 2. 5" wide, my existing turbo is about 6 across and 2" wide, I can't identify the original exhaust housing by the exh port casting # because it is still on the truck and in use,
    I don't know i'm from the old school and smaller outside meant smaller inside not bigger, could I be wrong on this one?
  12. #12
    Join Date
    Apr 2003
    Location
    Crestview Bus Garage Ashland, Ohio
    Posts
    4,473
    My 1990 has an "18" cast into the turbine housing and the 1993 has a "18. 5" cast. The 1992 has 21 cast into it!!!
    1990/1992 Dodge Rams modified by Smokehouse Diesel Ashland, Ohio
    ......therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38
  13. #13
    Quote Originally Posted by Greenleaf
    Greenleaf that doesn't help much, I know what it's supposed to have on as far as the casting stamp goes, But the turbo on the truck the casting stamp cm2 number isn't there, The modified hx35 the casting stamp isn't very clear it could be 16 or 18 but in the port runners the numbers look more like an 18,
  14. #14
    I find it quite unlikely that you'll have a modified Piers HX35 hybrid turbo with an 18 cm housing. But if you do, there's not much merit to "update" to a 16cm housing. The difference from 21 to 16 is a big step, but from 18 to 16 IMHO not worth worrying about.
    On another note . . . the 16cm cost only 150 bucks brand new from Piers. If you buy it, install it, and find out it is IDENTICAL to the one you have, you might be able to sell your "old" 16cm for $120 or so, easily. Investment: $30 bucks. How much value to you put on your sleepless nights worrying about having a too big one?
  15. #15
    Join Date
    Apr 2003
    Location
    Posts
    4,473
    Do you want part numbers. I have part numbers.
    The assy number of the turbo will not do any good.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
