Thanks Thanks:  0 Likes Likes:  0 Dislikes Dislikes:  0
Results 1 to 12 of 12
Thread: VE pump, AFC Banjo Bolt
  1. #1
    User Info Menu
    Does anyone have the part number for the banjo bolt for the AFC tube that goes into the AFC housing on the VE pump, and the seals?
    Newest: '15 LL, MC, Dually, Aisin, 3.73, Air Ride, Dual Alts, 5th Whl Prep w/B&W 3600
    '92, Reg Cab, Stepside, 37"s, Stack, TP Fiber Frt Fenders, NV4500
    '89, CC, SB, NV4500, SBC,16cm2, intercooled, FS Air Bags, Alcoa LTS,See It
    '97 Ram 1500
    '88 Ramcharger
    '49 Power Wagon
  2. #2
    User Info Menu
    No part number, but I have a few extra AFC banjo bolts- I'll give ya one for shipping. Seals can be had at any injection shop.
    Daniel
  3. #3
    User Info Menu
    check this out, no banjo bolt req
    it isnt there so it cant break or fall out and the steel line cant crack either
  4. #4
    User Info Menu
    I need 2 for sure and i would like to have an extra one
    '97 Ram 1500
    '88 Ramcharger
    '49 Power Wagon
  5. #5
    User Info Menu
    did you look at that link?
    for what cummins gets for 2 banjo bolts you can get 2 fittings and half a line
    its your truck but i wouldnt try to save 10 bucks just to have the steel tube break at the silver soilder - they are notorious for that. . .
  6. #6
    User Info Menu
    why not a barbed banjo and a barbed 1/8 " straight with 1/8 " silicone hose way cheaper then an fittings etc etc. . ?I'll have to dig a pic up. . .
    2000 Excursion XLT 4x4, P Pump 12V Cummins, O ringed, lazer DV, 370's, G56 6 speed, Southbend FE clutch, guages, 4" Remote BD Ex. Brake, full vinyl floor.
    http://picasaweb.google.com/therabbittree/Excursion02#
    1992 Dodge W350 srw 4x4, Getrag, 3.07's, PODs, guages, 5"stack, 8' dumping flatbed,
  7. #7
    User Info Menu
    Where did you get the barbed banjo? No one locally has them.
    DP
  8. #8
    User Info Menu
    Quote Originally Posted by therabbittree View Post
    why not a barbed banjo and a barbed 1/8 " straight with 1/8 " silicone hose. Way cheaper then an fittings etc etc. . ?
    cuz rubber hose cracks and wont stay on the barb under high boost conditions
    you can get 2 an fittings for 10 bucks
    tap the cover yourself
    and have a 8" line made for 15 bucks
    25 dollars and it will never break again
    wont ever push apart either. . . which is a big deal to me
    man, some of you first gen guys are tight
    learned a long time ago it is less expensive to fix things right the first time
    less of a headache too. . .
    don
    ps - i also needed a line for boost reference for a pressure regulator. that is why there is a tee in my set up
    pps - rabbit, have you checked to make sure you are getting full throttle?
  9. #9
    User Info Menu
    you can get the barbed banjo from bosch its factory on the vw diesels for the injector return fitting that goes on ve afc style pump. . . since i have a bunch of vw parts i had a few laying around. . the 1/8 " silcone and zip ties held fine on my twin turbo truck that saw 50 psi pretty regular. .
    the pump is definately getting full throttle the stop screw is there as a stop if i remove it its the same position.
  10. #10
    User Info Menu
    good deal. . .
    i wonder why i had to move the ball thingy on mine to get full throttle?
    just moving it to the inside hole wasnt even enough. . .
    had to oblong the hole!
    maybe its cuz when you turn the fuel screw in the idle comes up and you end up with a lot more throw?
  11. #11
    User Info Menu
    well my fuel is turned up as much it can go with out running away. . can't get it higher. . the idel screw had to be backed out a ton to get it to idle. . etc
  12. #12
    User Info Menu
    same here, but with the extra throw that those adj created i had a hard time getting full throttle
    thats weird. . .
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
