Page 1 of 2 12 LastLast
Results 1 to 15 of 29
  1. #1
    Join Date
    Apr 2004
    Location
    Moscow, ID
    Posts
    74
    Bleach in Fuel (sabotage)
    I'm posting this for my friend. Last night he was at a local supermarket with his 2003 quad cab diesel for a short time. He then drove his truck back to the fire house to report to duty. On his way to the station his "water in fuel light" came on. He also suddenly noticed a power loss, the engine started running rough, and a large amount of white smoke was emitting from the exhaust. The distance he drove was two miles. At the station he opened the water drain on the fuel filter and noticed a bleach smell. After removing the fuel filter it was confirmed that bleach was in the fuel. He has not recently fuel up and fuel level was half a tank at the time of the incident. Tomorrow he is towing the truck to a shop to have the tank removed and drained.
    1) Does anyone know what bleach can do to a diesel engine?
    2) Any ideas on additives or preventive damage control?
    3) Thank you for your help.
  2. #2
    Join Date
    Aug 2005
    Location
    Norfolk, Va
    Posts
    1,137
    I found this on yahoo answers. I would submit a police report and have him call his insurance
    05 2500 White SLT 48RE EGT, boost, tranny gauges. GDP 2 Mircron filter Fuel tank vent mod DRC light bar with Hella 4000's KORE Recon aFe Stage 2 w/ PG7 SMARTY Weathertech Floormats Line-x in bed and rocker panels 08 steering
    Looking for electrical job in Virginia Beach area
  3. #3
    Join Date
    May 2007
    Location
    Camp Lejeune, NC
    Posts
    103
    Bleach will soften rubber (some spray it on their tires to add smoke to burnouts. . . . whatever), I don't know if it affects all kinds or just the compounds in tires, but it might be something to watch out for.
  4. #4
    Join Date
    Feb 2000
    Location
    Winter Park, FL, USA
    Posts
    4,015
    I would recommend a locking fuel cap this will keep foreign liquids out of your tank.
    Bill Thomas
    Missouri Mule-96 Wht 4X4 ST CC,5 spd,3.54,8ft bed,1ft high cheater boards.
    99 Freightliner bl/wht FL60 ISB-5.9 24v,215 hp,520 tq,6 spd,3.59 nsr,16 ft box,19.5 tires,Wt/gvwr11000/23000
  5. #5
    Join Date
    Jan 2003
    Location
    Las Vegas
    Posts
    5,343
    Since bleach is a corrosive, I would have to wonder what it does to all the metal parts in the meantime.
    '03 3500 QC DRW 4WD 6SPD..SB DD3250 ,PMCR, aFe,torque tube,DD 2's,SPS 62/14, 4" exhaust, Titan,GN & 5'er hitches ,Autometer Phantom II pyro/boost ,XM radio .'93 W250CC ,NV4500, DISTRIBUTOR OF THE CHALLENGER & DOMINATOR CAR HAULERS, OWNER/OPERATOR OF DOUBLE M TRANSPORT
  6. #6
    Join Date
    Feb 2001
    Location
    Pacific Wonderland
    Posts
    1,529
    You can pop off a "locking cap" in seconds.
    2001.5 2500 4x4. Bombed by Piers, DTT, and Rip.
  7. #7
    Join Date
    Apr 2005
    Location
    Winnemucca Nv
    Posts
    251
    at least with a locking cap it takes longer to do the dirty deed. Having been sabotaged myself with drillers mud I can difinatly tell you it is going to take a while for all the ramifications to show up. If you can put it under Insurance I would. This may kill the seals in the lift pump and Vp 44 . Thats !!00 bucks right there well worth the insurance. If he knows anybody in particular at a good shop keep using them to do the work. It makes the paperwork a lot easier.
    Born 2001 Died 1/6/10,Timberline Green, 24v, auto, x-cab, s-bed, sirius radio, gps, straight pipe, 40+ injectors, HX 35 turbo, BD tranny, AFE air filter, 24.4 mpg
    1991 250 Red, standard cab, 5 spd, beat nearly to death
  8. #8
    Join Date
    Nov 2004
    Location
    northeast Iowa
    Posts
    820
    Quote Originally Posted by MMeier View Post
    I wonder too but we use bleach in our washing machines as well and it goes through our plastic drain tubes? Hmmmm.
    2015 Ram 2500 4x4 Laramie crewcab
    2015 Dodge Challenger RT Scat Pack
    Building trucks one Mumau purchase at a time!
  9. #9
    Join Date
    Feb 2004
    Location
    Midwest
    Posts
    74
    Sorry to hear your friend was sabotaged. If you can smell it over D2, the concentration must be at least high enough to be a significant concern for component damage.
    I would also call Chrysler and Cummins to get their suggestions on what to do and what may or may not be damaged. The answers could also help with convincing the insurance company to ante up.
    All polymers/rubber components are not created equal, so some may be susceptible to bleach and others not. The killer chem in bleach is the chlorine. This stuff is highly corrosive and left to it's devices will attack most all of the materials in our fuel systems. Chlorine causes rubbers to soften and decompose into a mass of jelly and it does not take much. I have seen this effect in weeks on incorrectly specified rubber components in chlorinated WATER systems! As for metal, chlorine will lead to stress corrosion cracking as the chlorine is highly reactive and will degrade the grain boundaries in all the metals in our fuel systems. This is a common problem in the food industry where chlorinated wash downs occur frequently. The situations I mention occurred over weeks to months. Hopefully, the short duration of exposure will not cause a problem in your friends truck.
    1)First order of business is to get the stuff out. NOW. Don't let it sit in there any longer than necessary. If it were me, I would do it as soon as I got it towed to a suitable place to work and pull an all nighter if necessary. Flush the low pressure side with clean D2 by disconnecting at the fuel tank and VP44 and running several gallons through. Set up a 5gal tank with fuel for a feed. Be sure to change the fuel filter.
    2) With that done, reconnect the line to the VP44 and crack the injectors, ALL of them. Crank the engine over and let it bleed. If it wants to run, that's ok. Point is to get the fuel out of the VP44 (might be ruined anyway) and get it out of the rest of the fuel system. Tighten up injector fittings and let it run.
    3) Now you can go back to the tank. Drain it, pull it and flush it. Consider going ahead and replacing the sending unit. If anything looks damaged or distressed, replace it. Insurance or not.
    4) Change the oil and filter. -Maybe more than once after you run it for a while.
    Then all you could really do is fill'er back up and drive it to see how it acts.
    Good luck.
  10. #10
    Join Date
    Sep 1999
    Location
    Riverside
    Posts
    11,203
    Quote Originally Posted by KevinSmith View Post
    To remove a locking gas cap all you have to do is pinch it while turning,it will come off in seconds and leaves no witness marks. I still have customers that drop off their trucks for some type of fuel tank service and do not leave keys
    Bob
    2005 2500 Quad 4x4 48re,Carli dominator 3.0 plus long travel air bags, Baja proven and enough power to make it work
    2015 TRD dcsb 4x4 stock for now
  11. #11
    Join Date
    Apr 2004
    Location
    Moscow, ID
    Posts
    74
    Thanks
    Thanks to all for such a quick response to this problem. . . especially Wrenchrat very informative! They are draining the tank and oil as we speak. Locking fuel cap on order, but from the sounds of things it may be useless? I will keep everyone updated with the long term effects of the damage. Thanks again
  12. #12
    Join Date
    Jun 2006
    Location
    "Rural" SE Indianapolis, IN
    Posts
    1,070
    Need a locking fuel door. BTW, who'd your friend p!ss off?
  13. #13
    Join Date
    Jun 2000
    Location
    Oak Bay, WA
    Posts
    911
    Did your friend file a police report? Sounds like he has ****** off someone. Have him check with the supermarket for surveillance cameras which may have captured the culprit in the act.
    2015 3500 SLT crew 4x4 auto w/5th setup, SRW, LB
    2008 Titanium 25e30 5th wheel w/B&W puck hitch
    1995 2500 SLT Club 4x4, auto, LB, .....SOLD.....
  14. #14
    Join Date
    Feb 2004
    Location
    Midwest
    Posts
    74
    No doubt, Landshark, might be sorta handy to know who's P. O. 'd so as to make amends or avoid or prosecute. Surveillance cams might help show it actually happening for insurance purposes if nothing else. Someone was obviously watching. . .
    It occurred to me that the perp may have actually been stupid enough to have actually purchased the bleach at the SAME supermarket? Hmmmm. Might be able to track back to a particular register by clothing and time and if the perp was even 'stooooopider' and bought the bleach with a credit or debit card, BINGO.
    If you want to consider doing this, you'll need to get the surveillance tapes quickly before they record over them. . .
  15. #15
    Join Date
    Oct 2000
    Location
    B-gard(Auburn) Alabama
    Posts
    1,065
    Chances are that the bleach was purchased at the store where it happened .
    We use bleach in our water plant. It attacks rubber and is very corrosive. If chlorine has something that it can react with it does just that. Chlorine does not just sit idle. When mixed with water it creates hydrochloric acid. Anything that has rubber in the fuel system will need replaced. What did it do to valves ,rings ,and cylinder walls ?
    Pitting ? If it happened to me I would have the insurance replace the entire engine(long block),fuel lines and fuel tank including filler neck. Why risk it?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
