Thanks Thanks:  0 Likes Likes:  0 Dislikes Dislikes:  0
Results 1 to 12 of 12
Thread: Fire department Service/ Brush truck
  1. #1
    User Info Menu
    Being a member of the local VFD we are in the process of researching the possibilities of a new Service / Brush truck. Since I am the lieutenant for the truck I would like to push for a Dodge/Cummins 5500 with an enclosed service body / brush truck body. Our current truck is a one ton International with an enclosed utility body.
    Is anyone a member of a FD that has a Dodge/Cummins truck? I would really like to see photos and hear your opinions.
    2001 Ram 2500 HD CTD 4x4,Auto, Quad Cab,SLT, LWB, Patriot Blue/Silver Two Tone
  2. #2
    User Info Menu
    Check this thread out, there is a bunch of pictures I took of the trucks I built for our fire department. What does your average bare bones flatbed weigh? - TDR Roundtable
    If you're not in trouble or causing trouble, you're not having any fun, and I'm having a blast! How about you?
    2014, 3500, 6.7, Aisin, DRW, 3.73, 4X4, Laramie, Crew cab, Sirius, 75 gal transfer tank, lights & siren
    06 Landmark, Mt. Rushmore 5th wheel, 40', wt 16k
  3. #3
    User Info Menu
  4. #4
    User Info Menu
    You might wish to rethink your needs. . . . I do believe that these are great trucks. . . . my 5500 now has 9,000 miles on it. . . . but what I don't think the factory has worked out. . . . is long idle times. . . If the DPF went through a self clean cycle sitting in a brush field you'd have a fire under the truck. . . . . .
    However we noticed that our truck has the ability to kick up the RPM with a switch across 2 pins for PTO speeds. . . this would be great for a pumper. . . . . flick the switch, engage the PTO and pump. . . . . . . .
    Knowing your going to have 20 guys who might run this truck and they will want to let it sit and idle while they wash it. . . . . or stop with a second truck and chat. . . . etc. . . . I just don't see it. . . .
    OTOH (on the other hand) where we use it as a highway truck. . . always at GVW and cruising down the highway. . . . . so far its a great truck. . . .
    Jim
    Retired Roaming America, 05 3500 4x4 Dually Molten Red stick, 125K miles, PacBrake Exhaust Brakes, 05 Jeep Grand Cherokee Limited, 05 Honda Rincon 650 ATV, 2001 Honda Goldwing
  5. #5
    User Info Menu
    You might want to check out these guys.
    Wildfire manufacturing
    They have done some really nice trucks on Cummins and Phord frames.
    The first one I saw was on this site 5 years ago. Its on Dave Fritzes site.
    Dave has more pics of it HERE!!!
    2001.5 D2500 QC SB SLT 4X4,
    DTT 89% TC & VB, Camshaft & HRVP44 from Massdiesel, DDII injectors, Garrett BB Turbo Stage II, FASS 150 fuel system, Bully Dog 5" exhaust, 315/70R17 BFG AT's on 102 Eagle Wheels, Reunel rear and Denver Offroad front Bumpers
  6. #6
    User Info Menu
    myself, build the truck for the mission at hand,
    - will the truck TAKEN OFF ROAD INTHE WOODS?
    -do you mined the truck getting scratched and dented or will it be pretty site on the hard road??
    -what do you want the truck to do and go????
    an yr old maybe two diesel 3500 would do nice, true suspension lift, real tires not ***** ones , winch, 250-400gal water, cafs sys. 4x4, regular cab, crew cab adds weight, beefy bumpper front and rear, tow hooks front and rear
    '06 2500 mega, auto, 4x4, 3.73, 285 E nittos, mopar bars, protected by Don't Tread On Me....
    STEFAN "THE SNUFF"
    Hug a Fireman.....Live the IAFF.....
    Hug a VET.....you might need them one day .......
  7. #7
    User Info Menu
    I pushed hard for a 95-98 Ram 2500 but our chief thinks ford's are cool.
    Consider a truck that is not easy to put on it's side and one that doesn't cost so much that if it gets totaled it puts your station in a bind. I know that's why we carry insurance but our dept. has a shortage of funds.
    Sounds like your talking "New truck".
  8. #8
    User Info Menu
    Thanks for the info so far. I never even thought about the Sterling Bullet
  9. #9
    User Info Menu
    Quote Originally Posted by stg2500 View Post
    I'm not trying to put damper on your project, I live in a very rural area that is extremely susceptible to fires. Our V. F. D. has a 08 powerjunck and we try to encourage them not to even use this truck offroad!
    I would suggest an older medium duty Kodiak 4X4!
  10. #10
    User Info Menu
    Quote Originally Posted by jelag View Post
    what if you put a single stack on the truck?
  11. #11
    User Info Menu
    yeah I feel for you . . our dept is so set on fords. . they are specing a new brush pump truck now and I havn't even looked at the tenative specs. . as the guys building it aren't diesel heads,,and think a 550 is the end of all ends. . etc. . oh well the 550 and the 5500 cummins probably have the same regen issues . . I don't even thing these guys know what regen is and I'd probably have to explain it to them. . its frustrating. . they are also doing a tandem axle tanker too. . and i'm not sure who or what for the same reason. . I just hope it has balls and a real engine brake. . a 160hp dt466 in a approx 1500 gal tanker/ pump sucks on hills
    Thanks
    Deo
    2000 Excursion XLT 4x4, P Pump 12V Cummins, O ringed, lazer DV, 370's, G56 6 speed, Southbend FE clutch, guages, 4" Remote BD Ex. Brake, full vinyl floor.
    http://picasaweb.google.com/therabbittree/Excursion02#
    1992 Dodge W350 srw 4x4, Getrag, 3.07's, PODs, guages, 5"stack, 8' dumping flatbed,
  12. #12
    User Info Menu
    Quote Originally Posted by therabbittree View Post
    Thanks
    Deo
    Deo,
    I here you on the non-diesel heads. Luckily, my Deputy Chief knows that I'm a diesel head and asked for some input. He wasn't sold on the Dodge until I showed him the cab and chasiss 5500. He definately wants the Cummins though You need to jump to the F-650 to get the Cummins in a Ford, which he said was way too big for what we need.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
