Results 1 to 5 of 5
  1. #1
    Join Date
    Jul 2005
    Location
    Indianapolis, IN
    Posts
    383
    Dump Trailer Won't Go Down
    I have a BIG problem. My dump trailer will not go down. It is a power up/power down. It doesn't make any "electrical click" when you hit the down button. I know it is not the remote. I have 2 of them and neither one works. I figured it is the selinoid. But is there any way to get it down manually until I can get a new one on Monday? Please help I hate having my hydro shaft exposed to the elements. -Jason
  2. #2
    Join Date
    Dec 2002
    Location
    Spokane WA
    Posts
    3,710
    The down motion on most dump trailers is just a bleed to let the hydraulic oil go back to the tank and the pump doesn't run. . . . . .
    I'd set the safety up. . . and use an ohm meter to test the wiring from the plug back to the pump assembly. . . . .
    Usually they are a 3 wire system. . . . one wire is a power lead and the other two are going back to the pump. . . .
    One wire trips a solenoid to power the pump in the up position and the other wire trips the drain back to the tank. . .
    Usually there is enough oil on the shaft of the cylinder so you don't have to worry about the weather. . . .
    These are straight forward systems but don't work on the system if its under the dump bed unless you have the safety up. . . .
    Jim
    Retired Roaming America, 05 3500 4x4 Dually Molten Red stick, 125K miles, PacBrake Exhaust Brakes, 05 Jeep Grand Cherokee Limited, 05 Honda Rincon 650 ATV, 2001 Honda Goldwing
  3. #3
    Join Date
    Jul 2004
    Location
    Avocado Capitol, So.Cal.
    Posts
    3,739
    If you are not electrically inclined then I would just loosen the the hydraulic hose to the ram , put a drain pan underneath
    2004.5 LWB 2wd , Volant cold air intake,custom H.I.D.'s w/Fogzilla 15,000 lumens forward lighting, 3" front lift ,Triple Pillar Gauges, Amsoil Dual Remote Bypass, CFM+ Intake. SMARTY JR. Straight piped, Goerend Trans parts
    Good Judgment Comes From Experience
    Experience Comes From Bad Judgment
  4. #4
    Join Date
    Mar 2001
    Location
    Columbia, Pa
    Posts
    601
    Look for a broken wire end, that has happened to me.
    Good Luck
    Cliff
    2001.5 Black Sport 4x4 Q-cab 6-Speed HO,3.54 - (((See Profile for))) - My Truck -Owner Operator ( Old Chickies Hill Auto Transport Inc. )
  5. #5
    Join Date
    Sep 2004
    Location
    Seattle
    Posts
    331
    Lots of hydraulic servos have manual drain back feature.
    Take close look at valve/manifold assy for stamped arrow and/or letters DRAIN with nut locked set screw or T-handle.
    Loosening ram drain back line could result in FAST down with lots of sprayed oil.
    In my career working around hydro servos every now and again in some machine room on the wall would be a oil outline of a person. . . ,
    2007 5.9 3500 SRW 4wd Auto Shorty Quad Silver. 2006.5 5.9 2500 4wd Auto Long Bed Reg Cab Molten Red. 2002 FLHT.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
