Results 1 to 8 of 8
  1. #1
    cable conversion for vacuum 4x4 actuator dana60
    Anyone know of a cable conversion kit for locking the 4x4 on the front dana 60 axle? can i buy it somewhere? my vacuum pump is shot but not leaking so i`d just as soon install a cable as go through the work off taking the vacuum pump off ,thanks
    FROM NEWFOUNDLAND CANADA (2001 DODGE RAM 2500 CAB-AND-A-HALF, 4X4 ,CUMMINS TORBO ,DSS INSTALLED ,NEW TRAC-BAR ,NEW WHEEL BEARINGS, BALL JOINTS,NEW TIRES,178000klms ,new powersteering pump,new wheel alignment.NIGHTMARE TO DRIVE!!!!!
  2. #2
    Join Date
    Nov 1999
    Location
    Rainier OR
    Posts
    1,442
    2011 ram 3500 DRW Laramie
  3. #3
    Thanks BOB V i think thats the product for me and they have a distributor in Atlantic Canada where i live.
  4. #4
    Join Date
    Jun 2000
    Location
    Oak Bay, WA
    Posts
    911
    Vacuum pump is also needed for HVAC controls and cruise control; so you will need to fix the pump anyway or come up with an alternate vacuum source.
    2015 3500 SLT crew 4x4 auto w/5th setup, SRW, LB
    2008 Titanium 25e30 5th wheel w/B&W puck hitch
    1995 2500 SLT Club 4x4, auto, LB, .....SOLD.....
  5. #5
    yea, i know, but i have had trouble with that vacuum system anyways,so i think i`ll still get the cable kit and fix the pump later. what will i do when i fix the pump and use the cable ,will i have to block the vacuum lines that go to the front diff?
  6. #6
    Join Date
    Nov 1999
    Location
    Rainier OR
    Posts
    1,442
    I would block the ONE line that goes to the transfer case. Should be able to find it above the master cyl
  7. #7
    Join Date
    Jun 2008
    Location
    las vegas, nevada
    Posts
    520
    I second what Bob V said. I just unhooked the vacume line on the tree above the master cylinder and put a cap on it. Everything works exactly as it should
    98 12v 4x4, 215hp pump, DDP stage 3 inj, #10 plate. 3k gsk, georend trans, ported fire ringed head W/ 60# V.S., PDR cam, II 62/12/65, AFE stage 2, 4" exh, carli suspension w/ 35's, lukes link, DSS steering brace, ATS exh. manifold, PosiLok, 4w disc
  8. #8
    i have the posi lock system on my truck. it wasn't as easy to install as i would have thought, and you can really only run the cable the way that the instructions state. but once i got it in and adjusted, this is the only way to go until you can afford a free spin kit. i use the truck in the woods and have lost 4 wheel drive due to a stick more than i can remember. it will not happen with this kit, short of one hell of a stick (tree). so far i am very happy with it.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
