Results 1 to 7 of 7
  1. #1
    Join Date
    Mar 2008
    Location
    Georgia
    Posts
    1,195
    no start. fuel shutoff valve?
    I'm looking at an older Case excavator powered by a 12 valve cummins with what appears to be a VE rotary pump. It has fuel pressure to the inlet of the pump, but won't start. Would the shutoff solenoid keep it from starting, or just keep it from stopping. Also, should it have power to the solenoid only to stop, or does it work some other way? Thanks in advance.
    '03 2500 SLT QCSB 4x4 HO6spd BSM 50's, Smarty Jr, AirDog, SBCDD3250, 35" ProComp Extreme MT2, Warn front receiver, TST used for gauges only, 260,000+Miles
    (Sold) '01 ExCab SB. 4x4. HO6spd. Engine mods & SBC.
    (Sold) '00 ExCab SB. 4x4. Banks box and built 47RE.
  2. #2
    Join Date
    Jan 2002
    Location
    Lincoln, Maine
    Posts
    6,398
    Quote Originally Posted by BDaugherty View Post
    Sounds like the shut off. You can bypass it to verify, running out front to check the procedure. Stand by. . . . . .
    2006 2500 4x4 Mega Cab SLT Auto 3.73's
    1997 2500 4x4 Reg Cab Auto
    2002 Chrysler T&C
    2008 Chrysler T&C
    2004 Cougar 290RKS 5th Wheel
    2006 Cadillac DTS Lux I (Hoopty)
    2015 Husqvarna M-ZT 52 (Gnome Killer)
    2013 Can Am Commander 800XT
  3. #3
    Join Date
    Jan 2002
    Location
    Lincoln, Maine
    Posts
    6,398
    You can unhook the power wire, pull the solenoid and remove the plunger underneath, the re-install the solenoid to seal the hole. If it starts you have shut off or electrical issues. Do not re-attach the wire while doing the test.
    Send me an e-mail and I will attach the page from the service manual.
    mwilson@freightlinerofmaine. com
    Mike.
    2002 Chrysler T&C
    2008 Chrysler T&C
  4. #4
    Join Date
    Mar 2008
    Location
    Georgia
    Posts
    1,195
    OK. Simple fix, right? No power to the fuel solenoid. I jumpered power and it started and ran fine. Now I just have to fix the travel pilot circuit and we can get it out of the corner of the building making it more accessible to fix the rest of the hydraulic system. Thanks for the great info.
  5. #5
    Sounds like a broke wire to me check it with a test light if it lights up t works just a bad connection
    Donovan volk
    Clatskanie,Oregon
    ___________________________________________
    1992 Dodge W250 Cummins /NV4500
    1983 Chevrolet Suburban Cummins /NV4500 1 ton 4x4
    in progress
    2002 VW Jetta TDI ,Piers 205 injectors
    1969 Peterbilt 350 Cummins small cam 500plus HP to
    the ground 15x4 trans
  6. #6
    Join Date
    Mar 2008
    Location
    Georgia
    Posts
    1,195
    The wiring is fine back around the engine. In the cab, someone removed the original computer and installed a lever and throttle cable. I don't know what other original controls were removed or bypassed. It ran like that for awhile, but then the hydraulics started acting up. Most of the electrical problems will likely be in the cab area. If I can get the travel circuit halfway working, I can get it out of the far corner of a building and into the open where I have more light and I can get my truck right next to it and not have to carry tools a distance.
  7. #7
    if it will run via a hot wire to the fuel shut off , just un hook other wires and run it that way is what id do
    Donovan volk
    Clatskanie,Oregon
    in progress
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
