Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 2 of 2
  1. #1
    Join Date
    Jun 2008
    Location
    Sykesville, MD
    Posts
    411
    TPMS Thresholds Reset Plus 2 TSB's 2013 Ram 2500
    Took my truck to the dealer today because I have two cab clearance lights with water in them. Not cool! Since I am running non-stock tires that are a different size and load rating than stock and run a different air pressures, I have been getting TPMS warnings since the day I changed the tires. Real PITA to see that come up in the EVIC every time I start the truck along with the yellow dash light! So I asked if it was possible for them to reset the light and heavy load pressure values for the rear tires. They did it, no charge. No more TPMS warnings! For the Goodyear Silent Armor 285's I am running I had them set the heavy load pressure to 65 psi and the light load pressure to 50 psi. I confirmed this with the folks at my tire shop. They did say that I could go as low as 45 psi as they know of people running them that low with no issue, but they said 50 psi would be more preferred. I left the default front pressure of 60 psi alone. So I am now running 60 psi in the front and 65 psi in the rear. As for the cab clearance lamps, they ordered a whole new set (all 5) and will call me when the come in. They performed did two TSB's while they were at it:
    TSB 18-018-13 PCM Reflash
    TSB 18-032-13 DCU Reflash
    The way the mechanic described them to me was that they were to fix erroneous readings in the PCM and the DCU. One of them, I forget which one exactly, he said came out just this month. If anyone has any more info on these TSB's, please post. Thanks!
    -Tim
    2013 Ram 2500 Laramie QC LB 4x4, Goodyear Wrangler Silent Armors LT285/70R17, Westin Chrome Ultimate Bull Bar, Weatherguard Saddle Box, Line-X Bed Liner
  2. #2
    Join Date
    Sep 1999
    Location
    Riverside
    Posts
    11,380
    Changing the values is opening up the changer to a legal can of worms. A PIN number is needed so the change can be tracked
    2005 2500 Quad 4x4 48re,Carli dominator 3.0 plus long travel air bags, Baja proven and enough power to make it work
    2015 TRD dcsb 4x4 stock for now
Similar Threads
  1. fifth wheel brackets 2013 ram 2500 with 6.7
    By hitchless in forum Product Research & Development
    Last Post: 11-20-2013, 12:43 PM
  2. First actual tow with 2013 RAM 2500 SLT 4x4 CC
    By Bug Out in forum 4th Generation Ram Forum
    Last Post: 05-28-2013, 10:09 PM
  3. Hello-New Guy with New 2013 RAM 2500 CTD
    By HorseMan-AR in forum 4th Generation Ram Forum
    Last Post: 05-26-2013, 10:17 PM
  4. First RV tow with the new 2013 RAM 2500
    Last Post: 05-09-2013, 03:30 PM
  5. TPMS reset
    By JSchooley in forum 4th Generation Ram Forum
    Last Post: 11-30-2012, 05:44 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
