Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 14 of 14
Thread: 91 to 93 grill
  1. #1
    Join Date
    Feb 2012
    Location
    Gettysburg PA
    Posts
    453
    91 to 93 grill
    Many of you may know this but for those of you that don't the grill for 91 to 93 trucks is no longer available from dodge. When I talked to my local deal he said there where 4 left in the country on dealer stock all on the west coast.
  2. #2
    Join Date
    Jan 2005
    Location
    cali
    Posts
    2,627
    Yeah Dealer want's an Arm and a Leg and your First Born for them Also
    running since Feb 2013 1985 dodge crewcab longbed 4x4 cummin's conversion
    R I P Speedy the bug 5-17-2010, sold 2008 2500 n 2011 3500
    new as of 5-11-2012 a 2012 jetta sport wagen TDI Wifes Ride
    2014 Jeep Grand Cherokee 3.0 Diesel replaced the Crashed Durango
  3. #3
    Join Date
    Dec 1999
    Location
    Gaston OR USA
    Posts
    1,414
    Keep in mind that LMC is coming out with an '89 to '93 catalog in the spring of 2014. I'm not sure what they will have but if you can wait it might be worth it.
    Bob
    1993 4X2 - 14 WG, PDR HX35, ATS exh, 4" exh, DD3+Injectors, "Green HP" Air Filter - custom intake, 6 gauges, 15%+ pump DennyT Stage II 3200 GSK. Horton fan, NV4500 5 speed, BD E Brake, 45 gal. Aero aux fuel tank, SBC, Tworline intake 394/880 0n #2 - 440/889 W/M.
  4. #4
    That is great, I have pinged LMC about coming out with a Dodge catalog on par with what they do for the Bowtie and Ford folks. Too bad it won't go all the way back to 1972 (or earlier).
  5. #5
    I wonder why LMC dont advertise that they are unless its just a hoaks ?
    Donovan volk
    Clatskanie,Oregon
    ___________________________________________
    1992 Dodge W250 Cummins /NV4500
    1983 Chevrolet Suburban Cummins /NV4500 1 ton 4x4
    in progress
    2002 VW Jetta TDI ,Piers 205 injectors
    1969 Peterbilt 350 Cummins small cam 500plus HP to
    the ground 15x4 trans
  6. #6
    Join Date
    Oct 2004
    Location
    Fairbanks, AK
    Posts
    201
    I noticed in Geno's catalog 81 that they are now selling 1st gen aftermarket grills.
    92 12V W250 CC Getrag; EsparD5, 4" exhaust, 16cm2 turbo housing, Fluidampr, KDP tabbed
    01 24V 2500 QC SLT NV5600 4x4; FASS hpfp, RV275s, Quadzilla fooler, turbo elbow, 4"exhaust, Jacobs brake, Timbo APPS, EsparD5, Carli, Amsoil, Fluidampr, SBClutch
    00 VW Jetta tdi
  7. #7
    Join Date
    Dec 1999
    Location
    Gaston OR USA
    Posts
    1,414
    Yes Genos is selling 1st gen grills. Their price is $245. 00 plus shipping. They do not have Dodge lettering at the top of the grill. If you search other web sites you can probably find them for a little less. Genos says that their might be some triming necessary for fitment. I saw a post that on TRD - I think - that said you can get the Dodge lettering off your old one but it not all that easy. They are heat pressed on.
    Bob
  8. #8
    Join Date
    Mar 2003
    Location
    Ontario, Canada
    Posts
    3,082
    Yeah, those grills have been available for a while. RockAuto is one name that comes to mind selling them. Granted, it would likely be a damaged part so Genos is still worth the money. . . . .
    Seen several in person. Not as nice as the factory ones. But better than an old busted one.
    President - Ontario Chapter TDR
    1990 Reg Cab W250 LE NV5600 6 speed, not so stock.
    1993 Crew Cab W350 Dually 97 12V NV5600 NP205 Dana 80 Air ride, Gear Vendors, HX35/HT3B
    2008 2500 Mega SLT 6.7 68RFE 4x4
  9. #9
    Join Date
    Jan 2008
    Location
    Mobile Alabama
    Posts
    18
    Ok so i was looking through JC whitney and i fell across this: http://www.jcwhitney.com/replacement...50224y1992g2j1
    Its a shame that i dosen't have the "DODGE" lettering (yeah i know good luck) but i kinda like the all crome look... any other opinions?
  10. #10
    Join Date
    Dec 1999
    Location
    Gaston OR USA
    Posts
    1,414
    I read somewhere that you can remove the letters from the original grill. I you look at the back side of the grill you will see that they are plastic, heated and pressed in place and could be removed if you have the ability to work with plastic. The letters are just mushromed using heat to hold them in place.
    Bob
  11. #11
    I bought a grille for my 92 on eBay if you look around you can get em for about 120 with free shipping they are a one piece you can also get the ones with the inserts but they are more and you have to buy the pieces separate lmc is coming out with a gen catalog in the spring
    John Deere yellow 1998 24 valve quad cab dually , the bumble bee
    1996 2500 chevy 6.5 diesel
  12. #12
    Join Date
    May 2003
    Location
    North Texas
    Posts
    3,179
    Check with some body shops... I recently saw a repaired one that had a new grille with the Dodge lettering... I havent' spoken to the owner yet.... only his wife. She didnt' know much, so I havent' tracked down the body shop, yet....
    Local Fix-it man.
  13. #13
    Join Date
    Jun 2006
    Location
    Edmonton AB Canada
    Posts
    2,116
    After reading this I contacted the Dodge guys I deal with. They confirmed that the grille was OBS but that they was 1 left in the Central Alberta warehouse. It's now in my garage. It was't cheap My buddy has 5 trucks that use this grille, 2 Ramchargers and 3 93 pickups with the CTD. David
    08 3500 QC Laramie LB 4X4 SRW 68RFE TCS Triple Disk Billet Converter, Mag Hitec Trans Pan, Hell Bent Steel 2" Front Leveling Kit, Adjustable Lower Control Arms, DSS Steering Brace, Smarty S67, H&S Trans Tuner, DPP Intake Hose, Isspro Gauges,- some parts "fell off"
    1999 Peak Frontier T279SL TT
  14. #14
    Join Date
    Feb 2012
    Location
    Gettysburg PA
    Posts
    453
    I found one in dealer stock by stupid luck and picked it up right before I started this post.
Similar Threads
  1. For Sale: NOS 91-93 front grill satin finish
    By Simplysmn in forum 1st Gen Non Engine/Drivetrain Ads
    Last Post: 05-05-2012, 01:07 PM
  2. Can a 91+ grill be put on a 90 - truck?
    By RSchwarzli in forum 1st Generation Ram Forum (1989 - 1993)
    Last Post: 03-05-2012, 06:57 AM
  3. Wanted: wtd: 91.5 intercooled coresupport and grill
    By stoneagemaxx in forum 1st Gen Non Engine/Drivetrain Ads
    Last Post: 12-04-2011, 12:08 PM
  4. Are there any other differences between the 89-91.5 models and the 91.5-93 models?
    By BushWakr - RIP in forum 1st Generation Ram Forum (1989 - 1993)
    Last Post: 12-04-2006, 08:46 AM
  5. 91.5 vs. 93
    By Sri Ram in forum 1st Generation Ram Forum (1989 - 1993)
    Last Post: 05-09-2006, 12:21 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
