Thanks Thanks:  0 Likes Likes:  0 Dislikes Dislikes:  0
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Thread: Ram 2014 3500 SRW with Aisin Availability
  1. #16
    User Info Menu
    If I purchase my 2014 without air suspension, what would be a fair cost for parts and install?
    2002 QC, LB, 4X4 SLT Plus, HO hand shaker 6, Jacobs brake,Limited slip. and a ton of Genos Garage options
  2. #17
    User Info Menu
    O about $350. 00 for kit (Yes you can Buy for Less) and $200-$300 on install.
    T&C Diesel 763-228-7121 Anytime.
  3. #18
    User Info Menu
    It should be noted that is simply adding "helper" airbags, which is completely different than the factory system. They will help with ride somewhat, but not like a true air ride system will.
    A system similar to factory such as a 4-tec or a Kelderman will cost 3-5,000 installed.
    Honestly, if you really want the air ride suspension, be patient and wait for the factory to produce them. I'm seriously considering trading my '13 in on a mid year '14. By the time you factor in the sure to be incentives and all mid year, I'm sure I can trade up cheaper than installing a Kelderman.
    '16 Eco Diesel Limited
    '16 3500 SRW Limited Megacab Longbed Aisin 4 corner Kelderman Air ride
    '14 2500 Laramie CCSB
    '13 3500 Laramie Longhorn CCLB Dually Aisin
    '07 Corvette Convertible Supercharged
    '99 Mercedes SLK AMG
    24' Regal Boat, Jet Skis, Snowmobiles, Motorcycles, Four Wheelers, Etc.
  4. #19
    User Info Menu
    Good advice. With that in mind, I think I will hold off ordering a 2014 untill after the first of the year and see if air suspension is available.
  5. #20
    User Info Menu
    Quote Originally Posted by jgillott View Post
    I have driven at least 2 2013 3500 SRW trucks with the Aisin. Unless they made some major changes in production for 2014 that I am not aware of, they are available.
    Were the 2 trucks C&C or PU?
    03, 3500, DRW, 6spd, 4.10, Transfer Flow 50 gal. aux tank, 4X4. Sold
    Semper Fi
  6. #21
    User Info Menu
    I don't think there are any factroy C&C SRW trucks.
    2013 3500 CC Laramie Dually Aisin 4.10s 8,820 Lbs empty, new 8-12-13, 98 gal Transfer Flow, 12KW Onan QD, Centramatics.
    2008 Holiday Rambler 32FKD TT
    SOLD 2003 White SLT QC dually, HO, NV5600, 4X4, 86K miles.
    85 Ramcharger Cummins conversion
  7. #22
    User Info Menu
    Quote Originally Posted by Kirwin View Post
    It is an OEM option on the 3500 C&C.
  8. #23
    User Info Menu
    Quote Originally Posted by Powder Extreme View Post
    TDC airbags have been avoided by commercial Manufactures for decades, I am sure it will ride better (Rams systems) I'm personally will be waiting, I don't think the single leaf will be strong enough for My liking. All commercial system's are Front/Rear Bags or Rear with cam arms, None are TDC.
    I looked at Kelderman it's the best there is, But $4K for I wanted, I just could not justify the cost.
    I always added leafs to my prior trucks (many) No one had the extra leaf for the 6102 spring 2013. You can add them to the 6101 DRW spring. I don't know if super spring has released anything for the 2013 SRW 6102 yet.
  9. #24
    User Info Menu
    Thanks AH64ID, hadn't considered that. It's interesting to note that the 3500 C&C is only available with 17" tires. Seems like a waste to spend that much money for a C&C and be limited to what two 17" tires will carry on each axle. The body builders guide lists 17" wheels only for D2 and DD. Might just as well get a 2500 if your going to use it for towing or hauling. I guess a service truck might be able to stay within the 6800 lb rear axle limit if they don't carry much. Not sure what other applications would work and stay within those numbers. Ken Irwin
    Quote Originally Posted by AH64ID View Post
  10. #25
    User Info Menu
    What's a TDC airbag? I'm not familiar with that term.
  11. #26
    User Info Menu
    Top Dead Center.
  12. #27
    User Info Menu
    Back on topic. Why is it that some dealers can order one and others can't. I'm looking at 13 vs 14 and the transmission is one thing that was making me lean to the 14. So I call my local dealer and ask about it. Truck manager (who understands what I want) looks on the computer and says only available with DRW in all trim levels. Now I'm looking on line and Im finding left over 13's for 10 grand cheaper than 14's on the same lot. what to do what to do?
  13. #28
    User Info Menu
    Quote Originally Posted by EastTexasDiesel View Post
    With just air bags as suspension, What happens when you are towing and get a leak??, i used to have a lincoln mark VII with air bag only system and i blew out a tire and it took out the air bag on that side, back then it cost 400. 00 to replace, just a thought before you order one, Monte
    2007 3500,4X4, MEGA CAB, 5.9,
    DMF gone G-56, 373, jake brake
    2015 Jeep Trail Hawk 4X4 - 9 speed auto, e-locker
    JESUS Is the ONLY way for salvation, DO YOU KNOW HIM??
    WB5MSF
  14. #29
    User Info Menu
    Yes. . . very strange that 1 day you can order a srw with aisin and the next day only drw with aisin. I think it goes to part availability.
    2014 3500 SLT BigHorn SRW 4x4 CC LB 3.42 AISIN
    1999 Alpenlite 5th wheel
  15. #30
    User Info Menu
    Quote Originally Posted by mfurrh55 View Post
    Semis, buses, delivery trucks, etc. have been using airbags only suspension for many years. Not really much to worry about. Sure it can happen, just like your leaf spring can break in half. I've seen it happen.
Similar Threads
  1. GPS Antenna on 2014 RAM 3500 SLT
    By 3500 in forum 4th Generation Ram Forum
    Last Post: 07-12-2014, 07:21 PM
  2. Any news on availability of 2014 Ram 2500
    By Wingate in forum 4th Generation Ram Forum
    Last Post: 09-21-2013, 10:53 PM
  3. Might switch to SRW for my 2014 3500
    By JHawes in forum Towing, Hauling and RV Forum
    Last Post: 08-25-2013, 09:40 AM
  4. 2014 Ram 3500 Air Suspension
    By SSteilow in forum Product/Accessories Forum (NO Engine/Transmission Discussions)
    Last Post: 08-02-2013, 10:57 AM
  5. 2003 Ram 3500 SRW 4x4 Larime Tires
    By RamThatStroker in forum 3rd Generation Ram Forum (NO engine/transmission discussions)
    Last Post: 11-11-2002, 03:58 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
