Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
  1. #1
    Exhaust brake quit working
    Hi,new to the forum,I have a 2007 5.9,exhaust brake was working just fine while going on vacation,all of a sudden quit,it is a factory cummins,it was installed by the dealer when truck was brand new,6 speed trans,the light comes on but no results,I took it today to a dealer here in Va,he said the vacuum pump is only making about 5 lbs,he said it should be 35lbs,is that correct,if so would that make it quit working,anything else I should look at,they told me parts are no longer available,can the pump be rebuilt,I do see there are some on ebay,please feel free to e-mail me,Thanks, Rick
  2. #2
    Join Date
    Mar 2006
    Location
    Central Virginia
    Posts
    226
    Go to Geno's Garage, a sponsor here on TDR, they have the both pumps and replacement diaphragms doe the Jacob's exhaust brake.
    2006 Quad Cab, Short Bed, SLT, 4x4, 6 Speed, Thunder Road, Line-X, Extang Tonneau, N-Fab cab length step bars, Pacbrake, Ram Mount Laptop mount, Banks Ottomind6 w/PDA, Trail Ready bumpers
    2000 John Deere 790. loader, box blade, grader blade, rake
    2011 John Deere 855d Gator
  3. #3
    Join Date
    Dec 2005
    Location
    Three Rivers, Ca
    Posts
    2,842
    Quote Originally Posted by hgreen View Post
    go to geno's garage, a sponsor here on tdr, they have the both pumps and replacement diaphragms doe the jacob's exhaust brake.
    ^^^this^^^
    My new rig:
    2016 BigHorn - 3500 - SRW - 4x4 - Aisin Auto - Crew Cab Longbed
    My old rig:
    2004.5 2500 4x4, 6spd, Quad Cab Longbed
  4. #4
    Join Date
    Sep 2002
    Location
    Huffing Diesel in Bothell Washington
    Posts
    5,323
    Welcome to the forum.
    Just to clarify, the exhaust brake you have was installed by a dealer (probably) but is definitely not "factory". Also, it's a "vacuum" pump so it doesn't make pressure at all.
    Good luck,
    Scott
    2003 Quad, 3500 SRW LB, 4WD, 6SPD, 305 H.O., 3:73 LSD. Smarty Jr., Westach Boost/pyro combo gage on pillar, SBC-ConOFE, FASS 95 Pump. PAC Brake. 1 piece DC driveshaft, GDP2u, 285/75-17 Toyo AT's, Centramatic Balancers, 6.7 HO HB, Finned AAM axle cover, Helwig Rear bar.
  5. #5
    Join Date
    May 2005
    Location
    Manteca, CA
    Posts
    884
    Kind of hard to imagine a dealer service dep't who concluded the Vac pump was bad but didn't try to sell you a replacement. Generally speaking, the pumps aren't repaired but just replaced when they go bad, which does happen often. The pumps sold by Geno's are quite a bit cheaper than the dealer or from Jacobs company. A search on this forum will net you several options for replacement, including buying from Cummins.
    Dan Avilla:
    '06 Laramie 4X4 loaded but stock, PacBrake, AMP running boards, Isspro Gauges, BD Cooldown, RideRites, SuperGlide hitch
  6. #6
    Hi, your right,not factory but dealer installed,never thought about vacuum pump not produceing pressure,dah,will the switch still light up even if pump isn't working,just seems strange this thing has been working perfect then all of a sudden not,thought maybe something electrical,I check fuse its good,how do I get to Geno's garage site,Thanks, Rick
  7. #7
    Hi, your right,not factory but dealer installed,never thought about vacuum pump not produceing pressure,dah,will the switch still light up even if pump isn't working,just seems strange this thing has been working perfect then all of a sudden not,thought maybe something electrical,I check fuse its good,how do I get to Geno's garage site,the dealership here in Williamsburg ,Va says part NLA,Thanks, Rick
  8. #8
    Join Date
    Sep 2002
    Location
    Posts
    5,323
    Yes, the switch will light up even after the pump is gone. It's been said (mostly argued) that the pump fails when there is a leak someplace and it has to run more. I think it's enough of a contributing factor that the system should be checked very closely for leaks after a repair is made.
  9. #9
    Join Date
    May 2005
    Location
    Manteca, CA
    Posts
    884
    When the diaphragm quits, it does so all at once. I think the pump itself might give signs like unusual noise, etc. but I'm not sure. When mine quit, I'm pretty sure it was the diaphragm but I just replaced the package with a PacBrake. The lamp coming on merely signals that power is being sent to the control valve relay.
    Dan Avilla:
  10. #10
    Join Date
    Jul 2005
    Location
    Warner Robins, GA
    Posts
    213
    If it were me with the dealer installed vacuum exhaust brake, I would remove it and install the Pacbrake. When I am towing I am in 26K lbs range and was so impressed with the PACBRAKE compared to the vacuum unit, I was like a little kid with a new toy. I use mine so much that I have had to replace the air cylinder on the unit. Coming down a 6-7% grade against the PACBRAKE was the must awesome thing. I had to turn it off a few times as I was slowing down GOING DOWN hill with the weight I had. PACBRAKE imho is the BEST unit as far as an aftermarket brake is concerned. No one elses can compare.
    04 Graphite 3500 QC 6sp/GV & 3.73 Marine Valve Cover, Pac Brake, Smarty, Autometer, SRT-10 Hood, B&W, 105 Aux Tank, Blacked out Headlights, FASS, Blue & Purple airbrushed flames, Eagle Alloy Black Wheels, Debadged, 46' Gooseneck Race Trailer, NHRA D2 Tech/Chassis Inspector
  11. #11
    Tanks for all the help,when I get back home I'm going to look into it a little more,I'm 400 miles from home right now,pulling a 30' camper,just will take it easy,I might change it over to the Pacbrake,if not and its the pump I see a couple on ebay or will see how to contack Geno's garage if I can figure out how to make contact with them
  12. #12
    Join Date
    Jul 2005
    Location
    Warner Robins, GA
    Posts
    213
    genosgarage.com
  13. #13
    genosgarage.com a better solution is to go with a bd. they mount there compressor in a better location than pac. both the bd and pac have a huge increase in stopping power over the jake. as our pumps fail we replace with bd's. it will take you about two hours to install. you can reuse the switch and ecm wiring. the jake has a longer belt than stock so you will need to change the serpentine belt to stock
    0635004x4duallyqcg56,dynatrac,,bd exhaust brake,m101181 donaldson muffler,cfm+ intake,winspeed delete,taylor wings,luberfiner bypass filter,smarty jr psm cold air,cool hose,tag,air tab's,reese 20k 5th wheel,pdr cam,ddp 50 hp injectors,62-65-13-ss,ss manifold+blankets,2 micron cat filter,hid and led
  14. #14
    Join Date
    May 2000
    Location
    Moab, Utah USA
    Posts
    202
    you can probably just replace the diaphram on the pump and be good to go! I just did this job, got part from Genos`, fixed in less than 1 hr. I ran a new section of hose from the diaphram to the solenoid eliminating the factory plastic tubing it did run thru(its inside wire loom with the wiring) Works great again. Just sayin
    06 3500 DRW 4wd 4dr auto,Jake, Inferno Red Laramie, , Luverne stainless boards, AFE super stock w air horn,PMS mod, Turbo Lifesaver, britebox w fogzilla, B&W turnover w Companion 5th wheel, Firestone airbags, rollup tonneau, Mag-Tec double deep pan, MBRP muff, juice w Att. 2" level kit
  15. #15
    price for the diaphragm only from genos is $159
Similar Threads
  1. Exhaust Brake Quit
    By DBradham in forum 6.7L Engine and Transmissions (2007.5+)
    Last Post: 03-16-2009, 01:17 PM
  2. Banks E brake quit working
    By MMcLeran in forum 24 Valve Engine and Transmission (1998.5 - 2002)
    Last Post: 11-27-2007, 07:07 PM
  3. Exhaust Brake Quit Working
    By BigMike in forum Towing, Hauling and RV Forum
    Last Post: 01-08-2007, 12:02 AM
  4. BD exhaust brake not working...
    By Jeff in forum 12 Valve Engine and Transmission (1994 - 1998)
    Last Post: 03-25-2006, 07:45 AM
  5. Exhaust brake not working
    By Turbo Terry in forum 2nd Generation Ram Forum (NO engine/transmission discussions)
    Last Post: 01-16-2002, 12:58 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
