Thanks Thanks:  0 Likes Likes:  0 Dislikes Dislikes:  0
Results 1 to 2 of 2
Thread: Transfer case torque capacity
  1. #1
    User Info Menu
    The article in TDR issue 39 page 23 states:
    'Both the NV 271/NV 273 transfer cases are rated at 1400 ft-lb input torque as was the NV241HD used previously"
    NV241HD: 5555 lbf-ft/11,000 lb GVW rating.
    NV271/273: 7890 lbf-ft/17,500 lb GVW rating.
    Even counting the above as maximum rated output torque when in low range both units exceed 1400 lbf-ft input torque capacity.
    There is a 40% increase in torque capacity of the NV271/273 over the NV241/241HD.
    Reference:
    http://www.newventuregear.com/tcases.html
  2. #2
    User Info Menu
    The dealer mechanic told me it was about half again as big and heavy too.
    2003 Quad, 3500 SRW LB, 4WD, 6SPD, 305 H.O., 3:73 LSD. Smarty Jr., Westach Boost/pyro combo gage on pillar, SBC-ConOFE, FASS 95 Pump. PAC Brake. 1 piece DC driveshaft, GDP2u, 285/75-17 Toyo AT's, Centramatic Balancers, 6.7 HO HB, Finned AAM axle cover, Helwig Rear bar.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
