1. HoleshotHolset
    Fill in the blank with the proper SAE specification.
    1) 6BT uses __________ bellhousing.
    2) 4BT uses __________ bellhousing.
    3) 6CT uses __________ bellhousing.
    4) N14, M11, BC - series, etc. engines use _________ bellhousing.
    HoleshotHolset , Apr 7, 2002
    #1
  2. brkoyle
    My guess is
    1) SAE #3
    2) SAE #3
    3) SAE #3 or 2
    4) SAE #2 or 1
    Bruce
    brkoyle , Apr 8, 2002
    #2
  3. HoleshotHolset
    cool!
    Unless I hear otherwise, you get a 4. 0 on this quiz! Oo.
    Matt
    HoleshotHolset , Apr 8, 2002
    #3
  4. w-cummins
    Well the 6b will take a SAE #2 I have one with it.
    and it it will fit on the 6 it should also fit the 4.
    so his 4. 0 is toast:)
    William... .
    w-cummins , Apr 8, 2002
    #4
  5. JLEONARD
    I agree that the b engines are usually set up with a #3, but a #2 will also fit.
    Don't know about the others... . never dealt with those engines
    JLEONARD , Apr 8, 2002
    #5
  6. Brian R
    What do these SAE numbers mean? Is #2 a Chevy TH400 or anything like that? Can someone please explain?
    Brian R , Apr 8, 2002
    #6
  7. Crash_AF
    No, I think it is the diameter of the bellhousing bolt pattern. . don't know which way it works though...
    Later,
    Joe
    Crash_AF , Apr 8, 2002
    #7
  8. HoleshotHolset
    A Chevy TH400 has a TOTALLY different bolt pattern than anything SAE related. The TH-400 can actually have a BOP (Buick, Oldsmobile, Pontiac) pattern or a regular old GMC/Chevy pattern..... this isn't to say that a bellhousing adapter can be bolted onto the Cummins and have a TH400 bolt up to the adapter... .
    BUT, SAE is SAE... . as long as you get an adapter for the right # SAE pattern and transmission pattern... you are set... . then getting the right flexplate and torque convertor is your next hurdle.
    I'd like to see a GM 4L80-E behind a Cummins... . other than the one that is behind the pricy Cummins/Hummer conversion project.....
    Darn PCM's... makes stuff more $$ to BOMB... . :D
    Matt
    HoleshotHolset , Apr 9, 2002
    #8
  9. w-cummins
    how bad would you like to see one? I have a 4l80e and NP 208 combo that I was going to use for my conversion before I got the NV4500, that I would let go cheap!
    w-cummins , Apr 10, 2002
    #9
  10. HoleshotHolset
    You certainly sparked my interest... ... PM me if you'd like.
    Matt
    HoleshotHolset , Apr 10, 2002
    #10
Loading...
Similar Threads - Cummins SAE Bellhousing Forum Date
6.7 Cummins into 68 Dodge? Cummins/Diesel Conversions Apr 9, 2022
05 Cummins in 84 chevy Cummins/Diesel Conversions Jan 8, 2019
Cummins NT855-GA Maintenance? Cummins/Diesel Conversions Aug 7, 2018
Share This Page
